Test pipe diameter size
Old Mar 27, 2008 | 02:52 PM
1781cc's Avatar
Default Test pipe diameter size
Trying to decide whether to nab a 034 3" test pipe or go spend a little bit less on an ebay 2.5" test pipe. Now, at first I thought that the 3" was a no-brainer but then I thought again that the test pipe is 3", but the down-pipe in my milltek is only 2.5" in diameter. My question is, since the downpipe is only 2.5", won't having the exhaust go from 3" to 2.5" and then to 2.75" be worse, or at least just as well as just going from a 2.5" test pipe to 2.5" down pipe to 2.75" exhaust?
I'm thinking that going from a larger diameter to smaller is going to create back pressure which will restrict flow.
second question:
on their site it states fits 2002-2005 A4 passats.. I'm guessing this is a typo? since it says fits B5s?
Old Mar 27, 2008 | 02:55 PM
Leifer's Avatar
Default RE: Test pipe diameter size
The flow velocity will choke somewhere in there, I'd recomend a 3" turboback, but since you've done the downpipe already, go ahead and see if you can do a 2.75" testpipe if you can. If not, then 2.5" is fine. The more airflow out, the better.
Old Mar 27, 2008 | 05:53 PM
Lazer Viking's Avatar
b6 and b5 test pipes are one and the same
if you plan on going with a larger turbo i'd say go with the 3" now
i have a 2.5" and am getting a 3" back done soon, so all i have to do is switch out the test pipe when i go bigger
Old Mar 27, 2008 | 06:14 PM
bolob5's Avatar
Go 3" with the BT. I had a 2.5 setup on my 98 w/ a k04 and am now going GT28RS with a 3" My exhaust guy said 2.5' or 3" there is no 2.75... If that helps with your decision. Search youtube for a guy with a 3.0" borla I believe, it sounds awesome; not cop lovin...
Old Mar 27, 2008 | 06:19 PM
cincyTT's Avatar
I'm make believe
Wont see much of a differnce between 2.5 and 3" on a stock turbo. Having the stock cat made to have a 3" in/out would be cheaper and still keep you legal (if you have emissions). The cat will only rod you of all of 1-2whp on a all out stock turbo setup. It flows really well.
green2man0
Nov 5, 2013 07:43 PM
jssteinke
Apr 7, 2013 03:11 PM
Niclipse
Mar 11, 2009 10:44 PM
jermdogg143
Mar 18, 2006 01:30 PM
greenday
Nov 29, 2005 03:43 PM
