Thermostat going out?
Old 02-25-2010, 02:01 PM
evan671's Avatar
Member
However, I think my directions are for the AWM motor only.
Old 02-25-2010, 05:30 PM
exequiel3k's Avatar
mine's a AEB engine -_-'
Darnit, your instructions were simple yet great enough to do the job... loll
Old 02-25-2010, 11:37 PM
BaconBait's Avatar
The reason your oil temp wouldn't go up is because the coolant also cools/warms the oil.
Old 02-28-2010, 01:02 AM
20002.8's Avatar
What weather conditions are you guys talking about driving in; i.e. temp..? thanks!
Old 02-28-2010, 01:03 AM
20002.8's Avatar
Also, motor is brand new with only 13,000 k
Old 02-28-2010, 01:12 AM
rvalternative09's Avatar
Default Thermostats/Engine temp
Hi
I have an Audi A4, 2.8 1999 model car. I noticed that the engine temperature needle stay's at C instead of being in the middle ie between C and H on the instrument panel. Also i noticed that the heater blows cold air. My car has a minor water pump leak. So i fill coolant once every 1000 miles. Is my problem ( Needle being at C) due to water pump leak or thermostat problem. The car has 133000 miles on it. Which one could be the best bet water pump or thermostat. I am trying know this so that i can plan my budget accordingly. I was told water pump replacement costs 1000 dollars and the thermostat around 100 dollars. Wanna take your advise before i spend even a penny on this car.
Old 02-28-2010, 03:46 PM
any suggestions on my case. Please refer to the id rvalternative09. I drive my in winter conditions.
  #18
Old 02-28-2010, 04:45 PM
vintravaia's Avatar
iseem to hav the sam problem, and then some. on my 2.8 a4 1998 can any one help find a mechanic in the area of nassua county long island. or someone who can work on the side???
  #19
Old 03-06-2010, 12:43 AM
20002.8's Avatar
Hey guys, check engine light was on with mine.. scanned for codes.. got P1296 'Engine Cooling system malfunction'...it's just the thermal temp. sensor. 17$ part changed out in 15 min.
  #20
Old 03-06-2010, 11:16 AM
leighsean's Avatar
Sweet bro glad you could diy. Ill be doin mine now thanks
Quick Reply: Thermostat going out?
