Thermostat stuck open?
Old Feb 9, 2009 | 09:57 PM
M3Armand's Avatar
Originally Posted by TheBat
Well I would feel one hose hot and the other not. I just hooked up a peice of hose to the core and blew water from a garden hose through it backwards. A lot of crap came out. I think it was silicone in the antifreeze that separated due to it being too cold. May have been the wrong antifreeze too.
But now I don't have any coolant flowing through the core, so I'm going to make a new post for that.
We "backflushed" my wife's heater core. A lot of sandy crap came out....A LOT. Afterwards, the heat came back! This certainly beat spending $2000 or so at the dealer for them to tear through the dashboard, put in a new heater core, but then end up with a lot of electrical issues since they didn't put the dashboard back together correctly...
Old Feb 10, 2009 | 05:58 PM
TheBat's Avatar
Yep, that's why these forums are awesome. The dealer wouldn't have flushed it.
Old Jul 22, 2010 | 08:55 PM
bigheathbar's Avatar
Default heater issue
2000 a4 it has 1.8t and is around 120k on it, and it now has the heater stuck on all the time. i thought about pulling the fuse but i don't want to damage the system by doing so. any pointers is this a frequent problem?
thanks
Old Jul 22, 2010 | 10:54 PM
ImTheDevil's Avatar
Change the temp sensor mentioned above. It's cheap and easy and should be done preriodically since they fail a lot on these cars. Start the car cold and let it run to warm up. Keep a hand on the lower hose. As the engine warms, if the hoses warm at the same rate the thermostat is stuck open. It seems to happen more on the V6 cars but there's no reason why it couldn't be bad on yours. You have all the symptoms of a failed t-stat so I'd bet that's the issue. And I agree - remove the Mickey-mouse fan wiring setup and put in a new thermal switch to control the fan properly.
JavanT
Oct 25, 2013 03:12 PM
Nemo S4
Apr 5, 2011 01:00 PM
hahaha251251
Apr 15, 2010 04:07 PM
fromzerophreak
Feb 15, 2010 02:40 PM
jedgaronzik
Feb 1, 2009 05:23 PM
