things that go wrong with ALL A4's
Old Nov 10, 2008 | 04:40 PM
  #71
deneb's Avatar
*Raises Hand*
'98 2.8 100k :
- The ghost sunroof problem
- Oxygen sensor
- Tie rod end, controls arm (front)
- Timing belt/water pump/V-belt
- The radiator was leaking
- Air mass meter
- Oil leak
- Washer pump was broken
- Rebuilt the ABS module with modulemaster
- Outside mirror was brown ...
- Door molding panel
- Gasket was leaking
Everything between 90K and 100k ...
that's it lol
Old Nov 10, 2008 | 04:46 PM
  #72
thagr81_us's Avatar
Seems like the ABS Module is a REAL commom problem... Just hate that there isn't really an inexpensive way to permanently fix this.
Old Nov 10, 2008 | 10:18 PM
  #73
EpicWin's Avatar
Did no one say drivers heated seats that get so hot they burn our asses?
Seriously folks, 6 settings! Any one of them after "2" on a 80k mile car is like spending a weekend at Guantanamo bay and knowing Bin Laden's hangout!
Old Nov 11, 2008 | 06:42 PM
  #74
Drfeelgood69247's Avatar
Ill second that my *** is on fire when i set it to 6. lol
Old Nov 11, 2008 | 06:59 PM
  #75
Darkprodo's Avatar
lol... you all went from common problems to every problems you've ever had.
A4
window regulators
abs control modules
upper control arm bushings
rear differential axle seals
DID pixelation
headlight washer cylinder jets
1.8t
cam tensioners seal / valve cover
vacuum leak (from broken hoses and check valves)
ignition coils
coolant flange / coolant temp sensor
diverter valve
2.8
vacuum lines / check valves
breather hoses
cam tensioner seals
3.0
coolant flange / temp sensor
ignition coils
2.7 lol... where to begin
cam tensioner seals
MAF
ignition coils
turbos
catalytic converters
those are common, what i've seen everyday for years.
Old Nov 12, 2008 | 07:50 PM
  #76
freakaftr8's Avatar
Member
Ok more cosmetic that drivability here but...
Dashboard material peeling up around windshield/piller area?
Mine is pretty bad. Is there a type of glue to repair it?
Old Nov 12, 2008 | 11:07 PM
  #77
genedaddy's Avatar
cv boots always cracking and breaking
hazard/blinker relay goes out
possessed sunroof
door trim (this is just annoying)
door locks, the carbon disk in the pump shattered
coil packs popping out
Old Nov 12, 2008 | 11:57 PM
  #78
Jc61990's Avatar
leather seats tear...
Old Nov 13, 2008 | 08:56 AM
  #79
thagr81_us's Avatar
I had the coilpacks start popping out on mine. Found the problem to be not torquing the sparkplugs to 20-22lb/ft. Might fix some of these from happening.
Old Nov 13, 2008 | 09:50 AM
  #80
airguard350's Avatar
Tech Guru
When my back hurts I set it to 6 and all the pain just melts away. It's the first theraputic car I've ever driven.
