Thinking about s4 swap.
Old Nov 23, 2008 | 10:37 PM
Loocsnaes's Avatar
Default Thinking about s4 swap.
My 1996 A4 has a major oil leak, I have wanted to swap it since i bought it, what are the pros and cons of this idea. i have found a 2001 s4 motor, 6mt, and the rest of the complete swap. Meaning the turbos, ecu, harness all of that. Is this really worth it?
Old Nov 23, 2008 | 10:47 PM
ty98a4's Avatar
no. but if you think it is go for it. if the motor ect.. is cheap enough do it.
Old Nov 23, 2008 | 10:51 PM
Loocsnaes's Avatar
I found everything for $3,000 and I purchsed the car 8 months ago for 2,000.
Old Nov 23, 2008 | 10:58 PM
airguard350's Avatar
Tech Guru
Eh, do it. It's not that big of a price difference between the car and motor setup. Sometimes you have to lay down serious cash just because it feels right.
Old Nov 23, 2008 | 11:07 PM
Loocsnaes's Avatar
The add says "engine complete from the oil pan to the intake manifold, turbos, inter-coolers, alternator, starter, power steering pump, A/C compresser, wiring harness, ECU, air flow meter, all attached sensors and brackets, 6mt transmission complete w/ used clutch, shift levers and slave cylinder.. " and also comes with a 90 day warranty anything else i would need?
Old Nov 23, 2008 | 11:23 PM
hiwords's Avatar
the custom bracket making will cost you the most. unless you know how. otherwise, it pretty doable if you are good with electronics
Old Nov 23, 2008 | 11:58 PM
gen2roller's Avatar
You'd be so much happier with an S4..
Old Nov 24, 2008 | 12:21 AM
Tech Guru
^ You are an S4.
Old Nov 24, 2008 | 08:30 AM
sinzbrosracing4a's Avatar
yeah id say do it if you have it
Old Nov 24, 2008 | 10:52 AM
euro_2nr's Avatar
with the $ and time you invest in it you'd be close to buying an S4 altogether, and then who knows how long the S4 engine and components will last. Not to mention the S4 will still have more creature comforts and your conversion will never have the same out-of-the-factory finish. something will always go wrong
