throttle body
Old May 19, 2010 | 10:41 AM
dannyboy01's Avatar
Default throttle body
I have had a mechanic mate look at my 1999 A4 1.8 non turbo B5 due to the slight flat spot from idle, he is pointing the finger at maybe the butterfly in the throttle body. I have read alot that it is quite common for the body to get cack build up inside and cause idle/throttle response issues, if i was to remove/disconnect it from the car and clean it up will i need to re-program anything when putting it back onto the car? cheers guys
Old May 20, 2010 | 01:19 PM
JayA4_B5's Avatar
Hi there I am currently experiencing the exact same problems! Although my mechanic did try to clean out the TB and no luck he also said that it cant be picked up by the vagcom in order 4 it 2 be aligned. I will have mine replaced by next week and ill let you know how it goes.
Old May 25, 2010 | 11:58 AM
JayA4_B5's Avatar
I have just had that TB replaced all my problems have been sorted thanks to that car drives smoothly and the idle has improved
kraylon
Sep 2, 2009 09:32 PM
SacTown_Vlad
Sep 12, 2007 03:56 PM
MilitantGrunt
Aug 13, 2006 09:01 PM
16w/A4
Jul 24, 2006 10:12 AM
