Timing on 2.8 - Aligned?
Old Aug 1, 2008 | 02:14 AM
Tweaked's Avatar
Default RE: Timing on 2.8 - Aligned?
^How would the car run OK if he was that far off? He'd likely have no compression or bent valves.
Old Aug 1, 2008 | 11:02 AM
aura0013's Avatar
ORIGINAL: auditech79
I can tell you that the crank in your diagram is about 100* off. The mark should be straight up and a little to the left. So your probably off by two to three teeth on the belt by your diagram. You should have a cam allocation fault in the ECM if thats the case though. Have you checked for faults?
diagram isnt to scale, the white mark on the pully is lined up to the arrow on the lower timing belt cover...
As far as the faults go, would a code / CEL scanner tell me?
Old Aug 2, 2008 | 09:50 AM
CRAZYHAWK's Avatar
Old Sep 19, 2008 | 05:51 AM
Spoke's Avatar
Member
A little hijack here:
I just want to check cam timing. My toothed belt almost disintegrated and I want to check cam-crank timing.
So in his picture, the cam pulley spacers should be exactly horizontal as shown when the crank is at TDC?
mharrington
Aug 31, 2014 11:09 AM
jmyong
Audi Q5
Dec 20, 2013 04:58 PM
audiSfour
B8 Models
Apr 28, 2012 08:22 AM
Audiguruforyou
Sep 20, 2011 01:31 AM
achTTung
Nov 11, 2007 10:40 PM
