timing belt concerns & questions
Old Jul 28, 2008 | 04:29 PM
jtreference's Avatar
Default timing belt concerns & questions
We bought a 2001 A4 Quat with 1.8T engine; used, had 115K at purchase (6 mos. ago) and since have replaced 2 rear wheel bearings. Still learning a lot about Audis (this is our first) but have read lots about serious damage sustained if timing-belt breaks; records for my car are not available, so how can I tell (1) if the timing-belt on this car has been changed/updated ? and (2) at what milage intervals should this rather expensive maintenance item be done?
Also read that the 1.8 engine didn't have the same timing-belt issues as other Audi engines, is this true? I don't mind doing maintenance, but with kids in college every penny counts, and I don't want to spend money on timing-belt if it's not necessary.
Thanks to all who respond!
Old Jul 28, 2008 | 05:43 PM
onepoint8tee's Avatar
Default RE: timing belt concerns & questions
You cant tell without records. 00/01's came with the updated tensioner, so thats good. If in doubt, just do it. It's cheap if you DIY. Do it every 80k.
I can't believe that post went through^!!!!
Old Jul 28, 2008 | 06:41 PM
ghost6303's Avatar
if you dont know when it was done, assume it wasnt. if you do it yourself (plenty of write ups on how) its about $300. its about $900 to have it done, its about $2-4000 if it breaks. either spend 300 now or gamble $4k and assume its been replaced, its up to you.
Old Jul 28, 2008 | 06:46 PM
coleA4's Avatar
You can always look at the wear on the belt, but even then you wont know exactly if or when it had done. Always better to be safe than sorry. Atleast its not the 2.8 thats a fun job
Old Jul 28, 2008 | 10:26 PM
BeatjunkieXL's Avatar
1+ for the better safe than sorry.
TSG
Jul 28, 2011 09:43 PM
rradovitch
May 16, 2008 06:02 PM
fairportA4
Dec 12, 2007 04:58 PM
Towlie
Dec 4, 2006 06:41 PM
nolander
Mar 22, 2006 06:31 AM
