Timing belt failure likely?
Old Jul 26, 2009 | 08:07 AM
  #31
a2thy's Avatar
Marks are aligned, new TB and water pump are installed, old tensioner still has plenty of tension. Going to do some other maintenance while the core support is off then crank it up and hope for the best. Wish me luck!
Old Jul 26, 2009 | 09:08 AM
  #32
hiwords's Avatar
good luck. sounds like you're having pretty good luck so far. makes so to put the serpentine on or back on correctly. if you're putting it back on, make sure to install it the way it came off. if you put it on backwards you could shred it. belt dressing helps too. also lube up all the pulleys you see.
Old Jul 26, 2009 | 10:43 AM
  #33
a2thy's Avatar
Yeah, no major snags so far. I bought new Duralast serpentine belts. The only directional markings I found on them was an arrow pointing in both directions longitudinally. I got belt dressing too. Can I use engine oil for the pulleys? or is there something else I should use instead?
Old Jul 26, 2009 | 08:41 PM
  #34
Midniteoyl's Avatar
He ment if your reusing the belts, they show go back on in the same dirsction. New belts doesnt matter, though I like to put them on so I can read the numbers.
Old Jul 27, 2009 | 01:23 PM
  #35
a2thy's Avatar
Oh ok. I'm guessing this is so the wear pattern on the old belts remains the same?
Old Jul 29, 2009 | 02:07 AM
  #36
Midniteoyl's Avatar
Yes...
And sorry for the bad spelling , late night and the internet was going down..
Old Jul 29, 2009 | 12:20 PM
  #37
a2thy's Avatar
No prob. Thanks for the info.
Old Aug 4, 2009 | 11:44 PM
  #38
a2thy's Avatar
Everything is back together and the car runs great! I really appreciate all your help guys.
Old Aug 5, 2009 | 12:44 AM
  #39
Midniteoyl's Avatar
WOOT!
Good job.
Sperrine06
Mar 21, 2013 09:21 AM
usmc_graves
Oct 17, 2011 10:18 PM
gary1005
Jun 28, 2010 07:06 AM
snogoer
Aug 3, 2006 01:59 AM
davehurwitz
May 8, 2004 01:52 AM
