timing belt problem????
Old Jul 7, 2008 | 10:18 AM
a4riderz's Avatar
Default timing belt problem????
hiseems to be a timing belt issue (jumped orbroken) with my car but before i even jump farther would it be possible to do a vag com or test to see if there is anything wrong before repairing the timing belt??? thanks!!!!
Old Jul 7, 2008 | 10:27 AM
rob67's Avatar
Default RE: timing belt problem????
1st thing i'd do mate is turn crank by hand to see if theres interference,assuming belt aint snapped!,if there is its a bent valve(s)
Old Jul 7, 2008 | 06:35 PM
a4riderz's Avatar
how wouldi know if there is a bent valve or not?? how can i check ??? thank you
Old Jul 7, 2008 | 10:56 PM
ghost6303's Avatar
take out your spark plugs and the timing belt cover, crank the engine over by hand, with a wrench on the crankshaft, 17 or 19mm if i remember correctly. if you hear a metal on metal sound in the spark plug holes and/or you the engine stops and wont turn any furthur by hand- you might be spending alot of money.
you can take the car (on a flatbed) to a mechanic and have them do a pressure check to see if the valves are holding pressure.
a broken/slipped timing belt wont throw a VAG code. usualy when this happens you know about it. how did you come to this diagnosis? was there a terrible noise right before your engine stoped?
and obviously, until you know for sure that the timing belt is ok and in the correct position DO NOT try to start the car.
Old Jul 9, 2008 | 12:38 AM
Tweaked's Avatar
If you think it's broken, pull back the timing belt upper cover and look.
If it's in tact, then spin over the engine by hand.
knole68
Jun 21, 2015 08:24 PM
Melchizedek
Apr 7, 2013 09:07 PM
yellow_submarine
Dec 31, 2010 10:24 PM
wemmington
May 31, 2006 05:38 PM
DLC1.8T
May 30, 2006 04:51 PM
