Tip Tranny slips when accelerating
Old Aug 23, 2008 | 02:30 PM
SlimChriz's Avatar
Default Tip Tranny slips when accelerating
Alright so when Im doing 75-80 and I floor it in 5th or 4th occasionally the tranny will disengage and obviously the revs climb when it happens then it will re-engage and revs drop. its happened twice now..
got a code the first time said the rpm were too high to engage that was when I was shifting from 4th to 5th under wot and had probly hit 100mph...but not entirely sure as at that speed noteing the rpms and speed are difficult while racing a mexican lookin dude in some dilapitated honda.
Now dont ask why im going WOT at 80...because I can I guess
Old Aug 23, 2008 | 03:02 PM
auditech79's Avatar
I would need the fault codes, it could be a slipping clutch pack, or maybe a sticking shift solinoid. Whatever the cause, i can't help you diagnose it without the exact code.
Old Aug 23, 2008 | 04:12 PM
SlimChriz's Avatar
Yah I didnt get a code the second time it just came out of gear it still accelerated some but noticably less then sliped back in.
Lately the shifts seem to be a bit rougher I have notice a little more fluid seapage would low fluid cause these symtoms.
I did change the fluid and filter 15k ago
Old Aug 23, 2008 | 07:47 PM
auditech79's Avatar
Oh yeah, low fluid will cause some severe damage to the tranny. I would stop driving it ASAP until you get the leak fixed.
Old Aug 23, 2008 | 10:24 PM
SlimChriz's Avatar
Aight ill get under it tommorow and check level hopes its not too low just checked it 3 months ago and it was fine...such a PITA to check though :/
I wouldnt really call it a leak just more seapage than normal...yes I know when it leaks its called a leak. Ill try to find out where its coming from and let yall know
Old Sep 6, 2008 | 06:44 PM
SlimChriz's Avatar
Fluid is fine got same code again
Control Module Part Number: 8D0 927 156 L
Component and/or Version: AG5 01V 1.8lR4T US D06
1 Fault Found:
01192 - Torque Converter Lock-Up Clutch
42-00 - Speed Deviation too High
Notice shifting has been rougher but slipping only seems to occur in 5th under acceleration
Old Sep 8, 2008 | 09:12 PM
SlimChriz's Avatar
5th gear is almost unuseable now except for cruising on level roads even slight inclines cause it to slip to keep the same speed anyone with input?...all other gears seem fine.
seems like a tourqe converter thing but why are other gears fine?
Old Sep 15, 2008 | 11:12 PM
SlimChriz's Avatar
problem went away for 2 days the came back worse tranny started making death squeal at anything above 3k rpm
Old Sep 16, 2008 | 01:07 AM
MrFlippant's Avatar
Problem Number One: It's an auto.
/thread.
/MrF being a dick
Old Sep 16, 2008 | 08:48 AM
SlimChriz's Avatar
yes problem # 2: some noob has been flogging the **** outta it for 8 years now lol
