tips on air bag light
Old Nov 23, 2008 | 04:55 PM
Sidewayzracer's Avatar
Default tips on air bag light
last night i pulled my steering wheel and column apart to clean the combi switch and once i had it back together the air bag light still stays on.
i dont know if there is a reset or not some where or if it goes away after a bit. Or if ill need to pull the column back apart and look for a unconected wire butim fairly ssure there isnt as i only disconnected the 3 for the air bag itself and the 1 for the air bag to the rotating hub whatchamacallit.
Old Nov 23, 2008 | 06:18 PM
Jc61990's Avatar
your probly going to need to check for fault codes then clear them with vag-com or at a local autozone...
Old Nov 24, 2008 | 02:07 AM
wasnt sure on this so i wanted to double check before i pull it all apart and it wont go away lol
thanx ill have the codes done latter this week
Old Nov 24, 2008 | 08:27 AM
sinzbrosracing4a's Avatar
yeah i pulled my wheel off to replace the ignition and the airbag light stayed on. you have to take it to the dealer to get it turned off.
Old Nov 24, 2008 | 11:58 AM
domperrion's Avatar
Member
You dont have to go to the dealer, but know someone with a VAG-com.
i dont think Autozone can clear the airbag light, maybe somebody can confirm that for sure.
Nic333
Oct 29, 2014 10:24 AM
jakej
May 22, 2009 11:11 PM
BradonWA
Nov 13, 2008 09:26 PM
