Total Vacuum Hose Replacement
Old Mar 10, 2009 | 11:51 PM
a2thy's Avatar
Default Total Vacuum Hose Replacement
Does anyone know about how much I'll need of each type of hose for a 1.8t AWM?
Old Mar 11, 2009 | 10:42 AM
a2thy's Avatar
Bump.
Old Mar 11, 2009 | 04:36 PM
a2thy's Avatar
Bump.
Old Mar 11, 2009 | 05:40 PM
pyropenguin's Avatar
Old Mar 11, 2009 | 09:58 PM
a2thy's Avatar
Whew, that DIY made my head spin. So many hoses and valves.
Will this DIY work for me even if I'm concerned with emissions, fuel economy, and fault codes?
Also, does anyone know if this DIY would apply to an AWM engine?
Old Mar 12, 2009 | 11:13 AM
hartsoe1's Avatar
needed about 8 ft of the little hose from advance for 2000 1.8, solved 'too lean' code problem.
Old Mar 12, 2009 | 11:24 AM
AutoUnionFan's Avatar
audizine is filled with cars that are modified for optimimum performance and "engine bay neatness" and many of the DIYs posted there will lead to constant check engine lights and failed emissions tests, so it is important that you consider your own goals before undergoing such mods.
like hartsoe1 said, you can order about 6-8ft of silicon hose to replace the small braided vacuum lines that often fail, this is a simple and OEM type procedure
Old Mar 13, 2009 | 02:54 PM
a2thy's Avatar
All the vacuum lines have the same inside diameter?
What kind of clamps should I use?
Old Mar 13, 2009 | 03:09 PM
I beleive the inside diameter is 4mm, a quick search can confirm this.
I used POS zip ties to secure my hoses I figure its not too critical for a vacuum line, and they are cheap. Knock on wood, they have lasted 20,000miles with no sign of failing.
Old Mar 17, 2009 | 02:56 PM
a2thy's Avatar
Thank you everyone! Wish me luck.
