Transmission 4th gear slip "problem found"
Old Sep 8, 2012 | 11:11 AM
jonbonesjones's Avatar
Moderator
Originally Posted by mrk3cobra
I found the input shaft at a shop In Hayward CA. The shop has thousands of used transmissions. The part was $80.00 and a complete rebuild kit with new clutches was $275.
I will start the rebuild today, and have the shop in Hayward rebuild the torque converter on Monday. The cost to rebuild the torque converter is $245.
Including new fluid I should be at around $800.00 after rebuild.
you could have bought an 01E for that
Old Sep 9, 2012 | 08:50 AM
Nollywood's Avatar
That's a fact. But it's all the other parts required - driveshaft, front axles, shift mechanism, subframe, mounts, flywheel, clutch etc that add up to a lot.
Then throw in labout, it's not a cheap exercise.
Old Sep 9, 2012 | 12:21 PM
Moderator
true. it would be easier with the v6 since the shafts are all the same. Always forgetting the 1.8 uses smaller axels.
Old Sep 9, 2012 | 02:15 PM
blackarachnid87's Avatar
Im having this exact same problem, if you would could you let me know how your project turns out, I may have to follow your same course of action
Old Sep 10, 2012 | 12:17 PM
2mikel01's Avatar
I'm having similar problems with my 2nd gear. Slippage in the low side of gear. I changed the radiator, as well as several other things in the build, so I've changed the tranny fluid. Still there. to be honest i dont know if i would try to re build it myself....
Old Sep 10, 2012 | 12:19 PM
2mikel01's Avatar
I agree. Post some more pics of the build.
Old Sep 12, 2012 | 10:39 PM
mrk3cobra's Avatar
I had a small set back, as you can see in the picture the reverse gear piston was cracked. I ordered one from ebay should be here friday.
Most of the transmission is rebuilt pictures to come.
Old Sep 12, 2012 | 10:41 PM
  #18
mrk3cobra's Avatar
here some pictures of the parts that are rebuilt waiting to go back in the transmission case.
Old Sep 12, 2012 | 10:49 PM
  #19
mrk3cobra's Avatar
Here is a picture of the valve body in the process or rebuilding it.
Old Sep 15, 2012 | 11:10 AM
  #20
mrk3cobra's Avatar
The new reverse gear piston came today. I rebuilt the drum and all the parts will go in the transmission housing today.
The tool in the picture is the only special tool I used in the rebuild, this is to compress the spring cups. There are around 6 spring cups that must be removed to get to some o'rings that need to be replaced.
