Transmission Fluid fill - overfill risk
My trans is slipping from 2nd on. I tried the fill up procedure with right trans temp twice. To rule out low trans fluid as a cause, I would like to 'overfill'.
We have a nice cold day today, so I could get the engine running, shift through gears (10 sec each), raise car, get fill plug out, insert the fill hose, and pump ATF in until if overflows. All with a much lower (say 10-20 deg C rather than 35-45 deg C as recommended). I assume this would cause a higher fill level.
What if any are the risks involved in do so?
If it solves my problem, I would know that it has to do with the ATF level (or pickup tube or filter or else).
If it does NOT impact the problem, I would just get the car to 35 deg C and take the fill plug out and let the extra fluid drain.
Input, please!
Input, please!
1998, 2008, 96, a4, atf, audi, b5, fill, fluid, low, overfill, overfilled, symptom, tranmission, transmission
