Transmission fluid pump.. tranny rebuild
Old Jul 23, 2011 | 02:58 PM
Lornnn's Avatar
Default Transmission fluid pump.. tranny rebuild
my car hasn't really moved (besides me pushing it) for nearly a month now and i figure its time to take care of it. the transmission fluid pump is toast and im assuming the torque converter went with it. now i dont know **** about transmissions - ive learned everything i know so far from my audi and its associated repairs with help from DIYs and this forum - so i found a local shop that will charge me $800 for labor if i bring them the parts.. and ive got my eye on a couple used trans - one from meloman here on the forum and one locally with quite a few miles on it.
question is:
will the shop have everything they need if i bring them a used tranny - assuming that everything goes as it should? or are there other connecting parts between the engine and transmission that i should consider?
any other advice?
thanks
Old Jul 23, 2011 | 03:14 PM
Andrew149's Avatar
question is:
any other advice?
thanks
they will probably need to order parts like seals and everything i would try to buy all the parts that the transmssion shop will need from ecs maby if you call them and ask they can tell you what you will need
Nemick
Sep 9, 2012 12:11 AM
Cbass
Mar 30, 2008 01:02 PM
TKneedsS4
Mar 16, 2008 09:04 PM
speed_racer_801
Mar 11, 2008 07:49 AM
