transmission issue i think
Old Jul 15, 2009 | 12:33 AM
dazzleboi's Avatar
Default transmission issue i think
hey everyone im new to this audi and forums thing but just needed a smarthead with this one, ok when i shift into 1st gear it makes a rattle noise but all other gears are fine ,one mechanic tells me its the sincros(hope i spelled it right) please someone help me if you can
Old Jul 15, 2009 | 09:46 AM
CCA4's Avatar
A bit difficult to say for sure based on that description, but its possible. "Syncro" is short for synchronizers, they're sorta like lil gates that keep you from shifting like a dipshit, say from 5th to 1st or something, while the car is moving. They do wear out. In addition to the noise you're hearing, is it harder to get the shifter into 1st than the other gears?
Old Jul 15, 2009 | 09:52 AM
ghost6303's Avatar
1st and 2nd gear synchros wear out often. especially from people trying to downshift from 2 to 1 while the car is still in motion. without anymore information thats all that i can tell you. you can try flushing the trans fluid.
Old Jul 15, 2009 | 01:45 PM
dazzleboi's Avatar
ok . so shifting in to 1st its not hard at all , every shift into gears are very smooth , now whats the cost of replacing the syncros, or do i have to replace the trans?
Old Jul 15, 2009 | 05:16 PM
ghost6303's Avatar
it would be cheaper and easier to replace the whole thing. new synchros will cost about as much as a good used trans will ($400-8000) let alone installation costs. i certainly wouldnt be thinking about replacing a transmission if the only symptom is a rattle.
Old Jul 15, 2009 | 06:22 PM
audi guru's Avatar
^+1
totally not worth it
Old Jul 15, 2009 | 11:21 PM
dazzleboi's Avatar
the rattle sounds like a motor that needs the main bearing replaced but its not the motor, thats what a mechanic said , so what would be the best thing to do ??
Old Jul 19, 2009 | 10:03 PM
the_ski_prophet's Avatar
I have the same thing going on with my 1999 A4 2.8 whats the possibility of damaging the gearbox further if i just keep driving with my synchros fucked? lemme know because I don't got a whole lotta money at the moment and would like an easy fix if possible.
Old Jul 19, 2009 | 10:09 PM
audi guru's Avatar
typically with our cars, there is no such thing as an "easy fix"
Old Feb 8, 2010 | 04:22 PM
lmorrow4's Avatar
This is not a syncro issue, it is apparently a chip in a tooth in the actual first gear that causes this problem. As you can see by the number of complaints about this, it is a fairly common problem with these cars although Audi doesn't recognize it as such. I've been told that first gear is an assembly that includes reverse but that the labor required to do this job is basically cost prohibative. I'm searching for more info myself on this issue. You really cannot even trade the car in with this noise because when they hear that noise they'll immediately tell you your car isn't worth anything.
