Triptronic Problem?
Old Apr 17, 2009 | 08:14 AM
Gagt518's Avatar
Default Triptronic Problem?
Is there a fuse for the triptronic feature? All of sudden it doesnt work. Doesnt do anything? Any advise? I checked the side fuses and nothing.
1998 A4 2.8
Thanks in advanced!
Old Apr 17, 2009 | 09:58 AM
The Bishop's Avatar
I might be that the magnet in the shifter has broken off. This happened to mine. In the rolling sleeve that moves with the shifter there is a magnet, when this magnet is moved over to tip mode it turns on tip mode, when you move the shifter forward and back to shift the magnet activates switches to tell the trans to shift. To check this out you have to take off the cover with the gear numbers and pull that sleeve out.
Old Apr 17, 2009 | 02:12 PM
Gagt518's Avatar
Is it easy to replace?
Old Apr 17, 2009 | 02:48 PM
The Bishop's Avatar
The shift **** is the hardest part to get off, It's not really that bad just takes a while. But if that is the problem then the dealership is $65 for a new one.
hfd#12
Sep 22, 2011 05:16 PM
audidriver08
Jun 13, 2011 11:53 AM
ryguy1825
Nov 2, 2008 08:12 PM
NYLATINO
Jan 21, 2007 12:13 AM
audihopeful
Mar 28, 2006 05:43 PM
