Trouble Codes
Old Jul 30, 2010 | 06:53 PM
devlzluv's Avatar
Member
Default Trouble Codes
Well got my obdII detector hooked up and got these codes, question is I know what they are but how do I go about fixing them.
Engine
16684/p0300-Random Misfire detected-any cylinder
16685/p0301-cylinder #1 misfire
16689/p0305- Cylinder #5 misfire
16690/p0306-Cylinder #6 misfire
17804/p1396-Engine speed sensor-missing tooth
17736/p1328-cylinder #4 knock control limit attained
SRS
01025-Malfunction Indicator Lamp Faulty
00532/p1746- Transmission Control Module Relay-Supply voltage (B+) malfunction Low Battery or Bad Ground
thanks in advance guys.
Old Jul 30, 2010 | 07:33 PM
morpheous's Avatar
move the ignition coil that's misfiring to another cylinder,to see if the misfire,follows that ignition coil,so you can rule out a bad coil.
Old Jul 30, 2010 | 07:36 PM
devlzluv's Avatar
Member
I was gonna replace all the wires and spark anyways, when I do that ill try. My main thing is that speed sensor missing a tooth.
Old Jul 30, 2010 | 07:39 PM
morpheous's Avatar
I almost forgot,take your A4 to a local Audi Stealership,our cars have a active recall on all the ignition coils in our engine,i had mine replaced free of charge about a month ago. ^_^
Old Jul 30, 2010 | 08:17 PM
devlzluv's Avatar
Member
I have the v6 and when I called they said no recall on those igntions. Only recall i have on mine thats still open is the ignition switch which im getting repaired tomorrow.
Old Aug 1, 2010 | 02:07 PM
devlzluv's Avatar
Member
anyone else ref the missing tooth
CStites
Dec 20, 2012 12:12 PM
Deekster22
Sep 13, 2009 01:22 PM
2000turbo
Nov 21, 2008 05:25 PM
edrocks3
Nov 1, 2007 03:03 PM
acvega
Mar 10, 2005 10:30 PM
