Trying to change rear O2 sensor on 1.8T
im having issues getting to the rear o2 sensor on my 1.8T i cant seem to get in a good position to get a wrench or socket on it and have the leverage to break it free.
im wondering what you guys have done to get at this lil bastard i allrdy wired up the universal sensor to the old wire and plug
I just did this a few weeks ago. I couldn't get it from above or below so i took the front wheel off and got to it from the side. There's a some kind of guard or heat shield that your probably need to remove if you do it the same way.
I haven't tried to do it on this car so I can't offer too much advice but be sure to have some Aerokroil or Silikroil (or, at the very least, PB Blaster - but the other two are much better) and soak it hours (at least) in advance. Also, don't use a cheap socket. I've rounded off sensors from trying crappy cheap sockets and now I use a good old Snap On socket.
if not ill have to look into it more i wouldnt think taking the wheel out of the way would afford a better vantage point to work on it
I'm thinking you may need the offset O2 sensor socket like this one (not sure about the size though):
http://www.sears.com/shc/s/p_10153_1...5&blockType=G5
Does anyone know what size O2 sensor socket is needed for the 1997 A4 1.8T? I was ordering some new "toys" (pickle fork set, etc...) from Sears and wanted to get the O2 sensor socket(s) I'd need while I'm ordering - that's what brought me to this thread.
Also have a 2001 A6 4.2, if you know what size O2 sensor socket it takes I'll get that one too. - Thanks
Yeah from putting a clutch in a 1.8T recently we learned that the secondary O2 doesnt look fun at all. Removing the exhaust seemed easier than getting at it in place lol. See about using a bunch of extensions and going across the top of the tranny from the driver side. It may not work but look at it - had to do an S4 that way.
beholder
Jun 1, 2010 08:00 PM
ride1157
Aug 24, 2009 10:44 PM
spiney
Jul 15, 2009 10:18 AM
