turbo bad?
Old Jan 9, 2015 | 09:58 AM
JoshuaMixon's Avatar
Default turbo bad?
i have a 01 a4 1.8T
i had an oil problem before with it (leaking badly) which i repaired. i drove it for a few miles after having repaired the leak and sudden loss of power and loud whistling noise. when i let off gas whistling noise becomes very very loud pressure release noise.
i have white smoke in my exhaust.
i believe it is a leaking turbo but i wondered about the whistling noise i hear when the turbo is spooling up.
any help or thoughts would be helpful.
Old Jan 9, 2015 | 04:28 PM
adam044's Avatar
They whistle when the go bad, white smoke is a good sign of a bad turbo as well. What is your PSI when you boost?
Old Jan 13, 2015 | 07:59 AM
i don't have a boost gauge installed, nor one available unless i get one. i do have a ross tech cable so if there's a sensor for boost psi i could get it from there. is there a sensor?
Old Jan 13, 2015 | 10:20 AM
MetalMan's Avatar
Your 2001 A4 is equipped with a MAP sensor (manifold absolute pressure) which is essentially a boost sensor. You can look at requested vs. actual boost in the Ross Tech VCDS program.
03a418tnate
Aug 10, 2010 08:07 PM
mr V8
18
Jun 23, 2006 03:21 AM
DickM
12
Mar 21, 2006 05:15 AM
