turbo charged 2.8
Old Jan 3, 2009 | 10:21 PM
Ramathorn's Avatar
Default turbo charged 2.8
ok to start this off i am just throwing this out as something to talk about and for ideas to people i currently do not have the money for something like this.
So i know pes makes a supercharger for the 2.8 which is ok for the money
I read some were that the 2.8 block can handle around 10 pounds of boost before detonation without internal mods.
So i saw this kit http://www.ststurbo.com/universal_system and i thought it could work.
the kit mounts from the rear so it would have room.
So would that kit work? how much hp gain estimate? possible intercooler? is the kit a decent product?
Old Jan 3, 2009 | 10:37 PM
somebody5788's Avatar
Ya you can do a rear mount its been done before. Personally I think its cheating hahaha. Idk just don't like them.
Old Jan 3, 2009 | 10:44 PM
ghost6303's Avatar
the search function is a wonderful thing.
https://www.audiforums.com/forum/sho...d.php?t=116070
https://www.audiforums.com/forum/sho...d.php?t=114489
https://www.audiforums.com/forum/sho...d.php?t=112670
https://www.audiforums.com/forum/sho...d.php?t=105506 post #4
https://www.audiforums.com/forum/sho...d.php?t=101551
it could possibly work, if you wanted to put twice as much money into this project as what the car is worth. HP gain would be tune-dependant, which would be a $1000+ stand alone system with custom dyno tuning, and you wouldnt make any more power on 10psi from a turbo then you would 10psi from a blower, just the way the power came on would change. an intercooler would be up to you to design. good luck.
Old Jan 4, 2009 | 10:36 AM
A4 Effort's Avatar
Furthermore, even if you were able to boost higher with that kit, you would still need to upgrade the 2.8 internals. I've seen a 2.8 after hitting 12psi......not pretty
As mentioned, it's been discussed many times and isn't really worth it
Old Jan 4, 2009 | 02:09 PM
euro_2nr's Avatar
10psi and your already asking for trouble. I think some other guy burned them at 10. Watta surprise.... a Junior fkn Member asking for V6 universal turbo's....
Old Jan 4, 2009 | 04:15 PM
cincyTT's Avatar
I'm make believe
Really? 10psi from a s/c would be the same amount of power as 10psi from a turbo
Last time i checked, 10psi from a ko3 is COMPLETLEY different than 10psi from a gt35r.
OP, those sts systems arent the best idea since the turbo is in a bad location and require way more parts. A good fab person should be able to make you a single or twin turbo setup that would make a good deal of power, even at a mild 5psi. At such low psi, most people on other car models can get away with a FMU which changes the fuel pressure in perportion to psi. These can be adjusted to change the fueling for boost for a safe a/f.
Old Jan 4, 2009 | 04:48 PM
anmagro's Avatar
So cincy, at 5psi, from these good fab people, how much power could be expected then? Enough to beat out the PES G2 Supercharger making 295bhp (212whp) @ 6.5psi?
Old Jan 4, 2009 | 05:17 PM
cincyTT's Avatar
I'm make believe
Depends on turbo size. If you went with something like a pair of gt28r's, i wouldnt be suprised of you put down 200-210whp on just 5-6psi even w/o an intercooler. If you went with something like a pair of gt3071r's, 230whp could probably be done. Cost wise, if you could fit a single turbo in the bay, a T4 50trim would be a nice way to get great power and only cost $700 for the turbo
Old Jan 4, 2009 | 05:20 PM
I have seen a big single done on a 2.7t but it aint pretty.
Old Jan 4, 2009 | 05:23 PM
cincyTT's Avatar
I'm make believe
got a pic you can put up for reference?
I dont know the 2.8's well, but if you could just use the stock headers and build off those, you shouldnt have much of a problem besides location for turboing the car. Have seen some top mount S4's however
