Turbo Help PLZ!
Old Oct 13, 2008 | 03:30 PM
9idua7's Avatar
Question Turbo Help PLZ!
ok i am going to be putting a new turbo in my 1997 audi a4 1.8t quattro and i want all or any advise i can get !! anything i should be weery of? or any issue that are common, any things i should do b-4 putting the new one on ANYTHING!! i do have the "sea foam treatment" and lucas synthetic with GTX high milage because it has 180,000 miles on it. but is clean and runs perfect and is flawless, (was owned by older couple and garage kept). but im getting off topic, but i was just hoping for any and all advise A.S.A.P.
thank you,
Dylan
P.S. what is the easiest way to get it out, and back in???
Old Oct 13, 2008 | 04:37 PM
ghost6303's Avatar
ok you have made atleast 3 identicle threads on the same topic. if you really have no idea how to do this then you really shouldnt be doing it. its fairly strait forward if you have some mechanical experience.
why are you replacing the turbo in the first place? is the other one failing? you say the car runs perfect so i dont understand. are you replacing the turbo or upgrading it? what are you installing exactly?
Old Oct 14, 2008 | 12:29 PM
9idua7's Avatar
ok my old one is seized up. and i've been told by people that i should post this in diffrent places so that i should get a better reply, i do know HOW to do it but it never hurts to see if i missed anything though. and im just putting another KO3 turbo in with a 12 LB waste gate.
Old Oct 14, 2008 | 01:20 PM
euro_2nr's Avatar
A straight swap is fairly straightforward. Just be weary of your lines
Old Oct 14, 2008 | 09:22 PM
Shwabmyknob's Avatar
Yea, I just did mine today, Make sure you get new oil lines. You'll also need new gaskets because the old ones were toast. The bolts are going to be a real B*tch to get out and you may end up snapping a few so you may want to be prep for that. Give your self plenty of time because you don't want to overlook or rush anything. Check all the lines make sure nothings hardened. If it seized it could be for a good reason so you may want to look into that. The line that goes into the bottom is a pain in the *** aswell, Good luck. Just dig in and if you run into problems you know where to post.
Old Oct 14, 2008 | 11:54 PM
cincyTT's Avatar
I'm make believe
First, please dont use GTX in your car. Use only approved oils. The easiest to find are Mobil1 0w40, Castrol Syntec 5w40 and Valvoline synpower 5w30.
Also, with that many miles on the car, you may want to do a compression test to see how the rings are sealing.
Lastly, the wastegate is only 5lbs
Old Oct 16, 2008 | 03:33 PM
EpicWin's Avatar
I have a spare K03-29 I could sell you, very low miles, stock boost. $125
Old Oct 17, 2008 | 11:24 AM
9idua7's Avatar
i wish that i would have talked to you earlier because i just spent alot more then that on a new one.
and does anyone know if going from the bottom of the car to access my turbo easier then just removing my air box??
Old Oct 17, 2008 | 05:47 PM
ghost6303's Avatar
if you are too lazy to remove your airbox which is all of half a dozen screws, you should not be replacing your turbo yourself. to answer your question- no its not easier, infact its impossible to remove the turbo from the under the car.
Old Oct 17, 2008 | 06:00 PM
Darkprodo's Avatar
impossible...?
haha. w/ the lock carrier in service position i'll guarantee you it will fall out the bottom
not practical... yes. you will have to access it from the bottom as well as the top. but it will end up coming out the top.
why do you keep attacking him?
he wants to replace his turbo... let him replace his turbo
