USP motorsport metal slave cylinder install
Old Sep 28, 2011 | 02:59 PM
SS92's Avatar
Default USP motorsport metal slave cylinder install
So my slave just went out on me in the middle of the road the other day, and I am now going to install the upgraded metal slave from USP. Has anyone else done the install here? I am stumped on how in the hell I am going to route the metal clutch line through the firewall. Anything I may have to remove? Avoiding tearing the car apart at all costs... Hard enough to work on the car at the apartment complex.
USP Summer Sale: Metal Slave and Clutch Line Conversion $150
That's the slave I'm referring to. Great deal on it too.
TIA.
Old Sep 28, 2011 | 03:19 PM
Mike-2ptzero's Avatar
I have been running it for some time now and have sold a good amount of those kits since many of my high hp customer also end up running a Flow Control Valve like I do.
What went into my car.
Why would you need to run the SS line thru the fire wall?
I just ran mine thru the same hole the stock hard line goes thru.
Old Sep 28, 2011 | 03:23 PM
SS92's Avatar
Thats what I had meant, it going through the stock hole. How hard was it installing the actual slave? i'm thinking of going from the top after removing the coolant res.
Old Sep 28, 2011 | 06:16 PM
meloman's Avatar
I think you'd have a much better time doing it from under the car, you get a lot better access that way
Old Sep 30, 2011 | 12:01 AM
SS92's Avatar
So I got everything in today, but I want to make sure I installed the new slave correctly. It took alot of force, and it kept the same resistance until I bolted it in. I wrestled with it for about an hour before I got it bolted back in, it kept springing back out at me lo.
Any help is appreciated.
tpaudi
Nov 12, 2012 12:36 AM
ChipDrive
Jun 17, 2011 10:10 AM
Pappa Phil
Mar 21, 2009 11:22 PM
GFBrummer
Aug 20, 2007 06:50 PM
kooldaddy
Jun 15, 2007 06:52 PM
