v-maxx coilovers
ok so i am planing on installing v-maxx coilovers on my 2000 a4 1.8T and i looked on audidiy.com how to install them and it didnt look too hard but i just wanted to see how long will it take me to take my original one out and put coilovers. if any one have done that please let me know
Do not follow the first steps that say to take the upper control arm bolt out... There is no need at all to do it and will make everything a lot harder. I swapped my suspension with vmaxx and it took me and my friend about 5-6 hours. Neither of us had any suspension experience. It's an easy diy, just takes a while so it helps to have some company.
You should handle a little better because of lower the center of gravity. They supposedly use the same spring rates as stock. How low do you plan on going? You may want to cut the bumpstops if you want low. I'm a little under 23" ground to fender and most people would think it rides terribly. I cut my bumpstops and it helped a noticeable amount but it's still rough over bumps and such. You get used to it. It should be a comfortable ride if you don't want low.
Quattro_1.8t
Mar 31, 2011 03:16 PM
