vacum diagram!!!!
ORIGINAL: pimphell
#13 on the chart is the N112 valve
#19 on the chart is the N249 valve
The chart that you have is correct for the vehicle. Yours doesn't match that chart?
On my #13, the N112 Valve - there is a right angle rubber fitting on the drivers side that is angled down to the ground and there is not a small hard line anywhere that goes into it. So:
- Does this valve vent to atmosphere or something? Strange to me to have a connector not go anywhere...
Thanks for the info on the MAF. Strange thing on mine (I also wrote this in another thread on this forum):
My P0171 comes on like clockwork just as the engine warms up, 4.5 minutes into driving (seems like it goes into closed loop mode), running down the road with light load.
I clear the code once, and I can be good the rest of the day. Sometimes at lunch the code will come on again, or I get a P0170 (misfire) without the light on, and it runs really bad for a while (or I clear that code).
So, if it was the MAF, wouldn't the CEL/code come on multiple times?
no the cel won't come on multiple times. It may only fire it once because of slight off mixture caused by the MAF or something in the fuel or sparksystem. Now if you get a P0170, I might be concerned about the same thing or even the plugs/coil packsin this matter.
Thanks for the fast reply and note on the MAF firing the code, pimphell.
I've been thinking about cleaning the MAF for a couple weeks now. I usually use MAF cleaner by CRC. Is that o.k., or for some reason, should I stick to the (denatured?) alcohol I've seen elsewhere on this forum?
I basically started the troubleshooting by checking vacuum lines, monitoring, and eliminating certain components via how/when the CEL comes on.
Then the other night went to yank out the MAF to clean. Shut the hood when I realized it was not going to be a quickie like on my BMW, or other cars where it is a simple two hose clamps, connecter and it is out of the engine bay.
I picked this car up with a broken timing belt. The belt cracked the crankshaft cover, gear, and also the oil pump tensioner. Had to fish some parts out of the pan, including some through the oil level/temp sensor hole. Thank goodness that was there or I may have had to yank the motor... Believe it or not, pistons and valves o.k. After a basic head rebuilding, put it back together... Picked it up for a sweet 3K, never hit Quattro. I tell my kids that it will be theres in 3 years.
Other Ramblings:
I am the type that really tries to narrow it down to a specific part, why it would be causing the problem - before buying parts. 35 years of experience in all kinds of makes and models, and it does not matter if it is electrical, mechanical, body, paint, interior, gears, motor rebuilds - I do it all except for - alignments (though I get them really close by eye before going in to my friends place) and trans rebuilds.
I've had 3 air cooled bugs and one water (passat) and I can honestly say that I was amazed as to how many friggin clamps are in this engine bay. Made me wonder if some designer had stock in a clamp company in germany. Come on, it is a 2001. Reminded me of one of the reason I got out of the air cooled - I had a 79 vert and the brakes were still manually adjusted via a total of 8 adjusters...
Other Ramblings:
Don't know about the alcohol
