vag'd my car, still no power windows.
Old Feb 14, 2009 | 07:55 PM
Audacity's Avatar
Default vag'd my car, still no power windows.
there was no fault codes for anything window related. unless the alarm has to do with the windows? anyone have any ideas, grounds are good(under kick panel) if thats not where the windows ground, someone let me know. theres no powerwindow fuse. any help would be awesome.
Old Feb 14, 2009 | 07:59 PM
Jc61990's Avatar
they wont go down at all or just not auto down or auto up?
Old Feb 15, 2009 | 01:22 PM
Audacity's Avatar
none of them go down. the sunroof doesn't work, theres no power to any of the window switches theres no power window fuse. and all of the clips under the driverside kick panel are fine. search my name you'll find the saga, i've been trying to figure this out for a while.
Old Feb 15, 2009 | 03:21 PM
Audacity's Avatar
anyone? brrrman i know you were helping me out. you have anything to add?
Old Feb 15, 2009 | 04:15 PM
sadik666's Avatar
I had the same issue before and the problem was the I think it's call the ''control unit module'' ...it's located at the rear in the passenger side rear fender. This module control the lock doors system and power windows. Look for the number on the grey plastic piece at the front to find the same one. I found a use one for 200$ (can) and it solve the issue. You might gonna have you remote key module to be reprogram since this module is in charge of door locks.
Old Feb 15, 2009 | 04:38 PM
sadik666's Avatar
actually it is call the '' central locking pump ''
Old Feb 15, 2009 | 08:41 PM
Audacity's Avatar
my locks work. why would my central locking pump be bad?
Old Feb 15, 2009 | 08:48 PM
brrman's Avatar
The central locking pump is actually the central locking control module. The pump is only part of it.
Old Feb 15, 2009 | 08:53 PM
Audacity's Avatar
ahhh alright, now were getting somewhere. thats how only part of it can go bad huh? hah *lightbulb* so what you telling me is locks can work perfectly, while windows don't work? is there any other symtoms of this? would my dome lights stay on longer than normal cause i noticed that too now.
Old Feb 16, 2009 | 06:00 AM
Audacity's Avatar
bump.
