Very Weird Issue
Old Oct 17, 2010 | 08:50 PM
choppedelight's Avatar
Default Very Weird Issue
I have a 2001 AUG motor from a Passat in my A4. I decided it was time to replace the plugs and once I took the first coil out of the motor, I saw a rusty colored corrosion on the metal part of the coil. The inside of the plug "silo" was also corroded. I took the plug out and the threads of the plug were also corroded and rusty. I then proceeded to take out the 2nd coil out. This one was perfectly clean and looked good. My question is, do you think it's electrolysis, a cracked block, or a bad o-shaped plug gasket that fits under the valve cover?
Old Oct 17, 2010 | 11:36 PM
joenelson7687's Avatar
Thats my first thought was the gasket in the valve cover. Its not hard at all to replace and certainly wouldnt hurt...
Old Oct 18, 2010 | 12:36 PM
good, i plan on doing that this winter at some point anyway. oil dripping on the cat. no fun.
Myst420
Jan 18, 2011 09:15 AM
cerealkilla1980
Feb 23, 2010 10:18 AM
pete7
Oct 30, 2008 11:23 AM
Warhawk
Jun 12, 2008 07:05 PM
docp
Feb 4, 2008 11:01 AM
