Vibration at ceretain speeds
Old Apr 29, 2008 | 07:03 PM
Quattro_1.8t's Avatar
Default Vibration at ceretain speeds
Any time I get above 55 mph my car will vibrate and I can't tell tell if its tire balance, or suspension components. I have 2 new Yokohama YK520s in the front and the rear tires are older pirelli tires and I'm not sure if the rears have been balanced recently. I had new lower ball joints replaced recently under warranty and new tie rods. The steering wheel does not vibrate at all its just the whole car in general and it does it at 55mph and 75mph the most, but even cruising at 65 it will do it a bit.
Old Apr 29, 2008 | 07:18 PM
cincyTT's Avatar
I'm make believe
Default RE: Vibration at ceretain speeds
I would check the wheel bolts first. Most likely they need tighten
Old Apr 29, 2008 | 07:39 PM
chaos92287's Avatar
and if that checks out, take your car to a tire place and see if they are balanced correctly.
since you said it wasn't in the steering wheel, it most likely means its the rear tires that are causing this, and since those are the older ones, it makes sense
Old Apr 29, 2008 | 07:49 PM
96A4Owner's Avatar
balance, misalignment, bent rim.
Old Apr 29, 2008 | 08:00 PM
chaos92287's Avatar
ORIGINAL: 96A4Owner
balance and bent rim...yes
misalignment...no
Old Apr 29, 2008 | 08:17 PM
96A4Owner's Avatar
i've been hearing that if you're car is out of alignment, a slight vibration can occur at higher speeds. Low tire pressure may also be the case but I highly doubt it.
Old Apr 29, 2008 | 08:25 PM
chaos92287's Avatar
someone told me that too, but auditech corrected me
Old Apr 30, 2008 | 12:55 AM
tire pressure is all good, it rode much smoother with the 18s on it then it does with these 17s so I'm thinking loose wheel bolt or bent wheel. Thanks for the info guys
robeggert90
Nov 26, 2014 05:37 PM
kahale5000
Jun 22, 2014 07:48 AM
maouloud
Aug 7, 2012 01:09 PM
2005AudiA4
Dec 21, 2008 08:59 PM
audi_sf
Oct 13, 2008 05:56 PM
