Wastegate issue?
99 a4 1.8tqt
Exhaust leak at Flange/cat
Because of the leak I can hear the turbo pretty easily. It starts spooling up as soon as I step on the gas. Boost hits around 5-7 psi and vac goes as low as 30 while driving. I've got a CEL throwin p1136 (too lean?) im assuming thats from the exhaust leak. Any idea why the turbo's spooling up this much?
Well being that the turbine wheel is driven by exhaust gas, it spins whenever the motor is running. All the boost/vac lines, the N75, and the DV/wastegate are what control how much boost actually makes it into the intake mani. Your boost/vac numbers sound right, maybe you're just hearing it more now than you did before because of the leak?
I thought it was a bit low too, i usually run about 22 at idle, ~25-26 when coasting at speed, but never lower than that. I've never heard of TOO much vacuum before have you?
haha 30 is not a lower vacuum, its a higher vacuum and i idle at like 22-24ish depending on the temp of the car and outside temps and if any of the aux stuff like a/c or whatever is running and every once in a while ill get 30 out of it when coasting in gear.
