Wastegate issue?
Old Oct 4, 2010 | 11:35 AM
DRWonoski's Avatar
Default Wastegate issue?
99 a4 1.8tqt
Exhaust leak at Flange/cat
Because of the leak I can hear the turbo pretty easily. It starts spooling up as soon as I step on the gas. Boost hits around 5-7 psi and vac goes as low as 30 while driving. I've got a CEL throwin p1136 (too lean?) im assuming thats from the exhaust leak. Any idea why the turbo's spooling up this much?
Old Oct 4, 2010 | 11:53 AM
CCA4's Avatar
Well being that the turbine wheel is driven by exhaust gas, it spins whenever the motor is running. All the boost/vac lines, the N75, and the DV/wastegate are what control how much boost actually makes it into the intake mani. Your boost/vac numbers sound right, maybe you're just hearing it more now than you did before because of the leak?
Old Oct 4, 2010 | 08:50 PM
DRWonoski's Avatar
so this should be fine then? I'm replacing my DV this coming weekend with a 710n and then hopefully getting a custom exhaust this weekend as well... we'll see.
Old Oct 4, 2010 | 11:44 PM
joenelson7687's Avatar
30 is a really low vac number, IMO.
Old Oct 5, 2010 | 07:40 AM
CCA4's Avatar
I thought it was a bit low too, i usually run about 22 at idle, ~25-26 when coasting at speed, but never lower than that. I've never heard of TOO much vacuum before have you?
Old Oct 5, 2010 | 11:39 AM
shortyxc's Avatar
Too much vacuum? I guess it just means you car "sucks" a lot lol
Old Oct 5, 2010 | 11:52 AM
Audacity's Avatar
haha 30 is not a lower vacuum, its a higher vacuum and i idle at like 22-24ish depending on the temp of the car and outside temps and if any of the aux stuff like a/c or whatever is running and every once in a while ill get 30 out of it when coasting in gear.
Old Oct 5, 2010 | 06:10 PM
DRWonoski's Avatar
yea those are closer to my actual numbers. I dont think i've ever actually seen it hit 30. Idle around 24 and get 26-28 coasting. Around 2k i'm at 0 though...
Old Oct 6, 2010 | 10:02 AM
Maybe it cause I have tip, but when in park im at 20, in gear im at 15, and itll drop to about 25 (temporarily) when i let off the throttle at cruising speeds
Old Oct 6, 2010 | 12:19 PM
DRWonoski's Avatar
i'll take it for a ride today and get the exact numbers for you.
