Water pump leaking 96 quattro 5speed
Old Nov 4, 2013 | 09:45 PM
86f250xlt's Avatar
Default Water pump leaking 96 quattro 5speed
On my way to work I was about a mile from work and my low coolant light come on! I finished driving to work and worked my ten hour shift and I remembered to get a gallon of coolant when I got out to my car there was a wet spot about the size of a basketball I checked the reservoir and it was empty I poured some coolant in drove home and checked again... Almost empty again and now I can see coolant running down the front off the engine and dripping off the oil pan!
I am trying to decide now if I want to fix the 2.8 v6 or park the car and put my truck back together and wait for me to find a 4.2 v8 for the car?
Or to sell the car...
The car has less than 115,000 miles
Old Nov 5, 2013 | 10:01 AM
turbo510's Avatar
Whatever you decide, don't drive that car until the water pump seizes. The TB will break shortly after and then the whole thing is a basket case. Is that the original WP? If so, maybe the original belt and rollers too? A whole kit is $179 at Germanautoparts.com for example, and the job isn't that tough.
Old Nov 5, 2013 | 03:34 PM
86f250xlt's Avatar
I believe the engine is all original... I have done a little bit of work to it, and it doesn't look as if any of the bolts have ever been removed
Old Nov 6, 2013 | 11:07 AM
turbo510's Avatar
That's really risky if those parts are all 17 years old. If you hear any kind of unusual noise from the front of the engine, I wouldn't drive it. If the belt goes, you instantly have bent valves in the cylinder heads.
The Blauparts kit is a good deal at $215 I think, because you also get a new serpentine belt, thermostat, coolant, and some seals for the cams and crank. For $50 more you can get a cam locking bar from Koch tools.
Old Nov 6, 2013 | 02:41 PM
mtroxel's Avatar
If I'm reading between the lines right, I'm betting not just the water pump is original, but the T Belt too. The Audi gods will punish you if you don't do a T-Belt kit along with the water pump.
speakoutp
Nov 27, 2014 06:51 PM
cheetoz49ers
Jan 31, 2013 09:41 PM
AudiMitch
Mar 9, 2011 01:39 PM
hahaha251251
Apr 15, 2010 04:07 PM
