well balls... clutch?
Old Sep 7, 2010 | 07:26 PM
colony777's Avatar
Default well *****... clutch?
well i just did a launch, and right afterwards the tranny locked up and wouldnt let me shift. i forced it into gear to go right back down to my house, and as i was going up my driveway and it was whining, then it stopped moving. i can now put it into gear without using the pedal at all. clutch, slave/master cylinder, tranny? it has a spec clutch currently, which i am aware sucks. will i be able to keep my aluminum flywheel if i get a southbend?
Old Sep 7, 2010 | 08:41 PM
Mike-2ptzero's Avatar
Sounds like your clutch went.
If you launch the car often stick with a 6 puck, if you do it once in a while you could get away with a Kevlar disk setup if you go with a 240mm setup like the CM kit.
Yes you can use your aluminum flywheel with a south bend or CM clutch if it is a spec flywheel, that flywheel is cut to be just like the OEM flywheel. You might need to replace the friction plate on the flywheel.
Old Sep 7, 2010 | 08:50 PM
Tweaked's Avatar
Most common failure I find is a broken pressure plate. As long as your flywheel isn't damaged, overheated, or gouged to the point of no repair, you can reuse it. You'll need a clutch kit, however.
Old Sep 7, 2010 | 09:04 PM
colony777's Avatar
that damn clutch always used to chirp when i would let it out slow at higher rpms and it didnt catch till it was the whole way out. also, when i push the pedal the whole way to the floor and hit the gas, a sound comes from the transmission that sounds like a deck of cars being shuffled. i just dont see how it went out in a bang, or why i couldnt shift into gear
Old Sep 7, 2010 | 09:12 PM
Tweaked's Avatar
The rattling noises atre likely from the flywheel. Audi used a dual mass flywheel to reduce the noise, vibrations, and harshness from these cars. A clutch will go out like a bang as you've described when the pressure plate breaks.
Old Sep 7, 2010 | 09:14 PM
colony777's Avatar
well i dont have the audi flywheel i have the spec aluminum one
Old Sep 7, 2010 | 10:11 PM
The noise you most likely hear when you have it pushed all the way in is the fingers bottomed out on the disk. Seen and heard of a few people with a Spec clutch having that same issue, I had that problem with a Spec 240mm kit on a customers B6. It was the first Spec clutch I sold and also the last.
Old Sep 7, 2010 | 10:28 PM
colony777's Avatar
thanks for the input guys. im gonna be changing it myself, for the first time. i have all the drive shafts unbolted so its a good start with no rounded off bolts
Old Sep 8, 2010 | 11:32 PM
colony777's Avatar
well after 2 hours last night and 3 tonight, my tranny is finally laying on my garage floor. turns out that the pressure plate and flywheel look brand new, but the disc completely broke in 2. do you guys think i should just get a good disc and keep the clutch pressure plate (its a stage 4) or get a whole new kit?
Old Sep 9, 2010 | 02:20 AM
Throwing in just a new disk wont last very long, its like throwing on new pads on old rotors. The flywheel and pressure plate need to be resurfaced before putting a new disk in.
You could call up Spec and tell them their disk broke, but good luck with them actually doing anything about it.
