what is better?
Old Dec 17, 2008 | 07:06 PM
roman_pushkin's Avatar
Default what is better?
I currently own a 98 audi a4 quattro 2.8, but looking into purchasing a 1.8t quattro and i am not sure which one i should go with! Any advice would be helpful
Old Dec 17, 2008 | 07:31 PM
flynnr's Avatar
get a 99.5 to 01 1.8t
Old Dec 17, 2008 | 10:23 PM
y how is it better?
Old Dec 17, 2008 | 10:32 PM
MissionCtrl's Avatar
Well it depends, if you just want it to look good and throw a stereo in it, stick with the 2.8. If you want it to go fast and all of the above, then the 1.8t is what you want. as for what year, well that just personal preference. 96-98 you get the AEB engine, which is insanely tough and flows good(head). 99-01 you get better headlights, tail lights and an engine that comes with 170hp stock as opposed to the 150 in the 96-98's. Might be some other differences with the 99 and up but i can't think of them right now.
Cheers,
Josh
Old Dec 17, 2008 | 10:54 PM
nova_ss672001's Avatar
^^^ yup i agree...if you want lots of engine mods and wanna go fast get a 1.8t quattro...
but if you just wanna cruise and have a sexy car go with the 2.8...
Old Dec 17, 2008 | 11:35 PM
B5 owns's Avatar
only the 2001 b5 comes with 170hp due to the ko3s and some other engine changes.
Old Dec 18, 2008 | 12:33 AM
oh i thought they just upped the boost 2psi.
Old Dec 18, 2008 | 02:51 AM
thanks guys
Old Dec 18, 2008 | 03:12 AM
A4speed's Avatar
nope, psi is the same. 01+ comes with 170 hp.
so buy a 2001+
Old Dec 18, 2008 | 02:10 PM
onepoint8tee's Avatar
97-99 1.8t AEB engine= best for mods. No tatle tale map sensor and larger exhaust ports for better flow when heavily modded. No taxing secondary air pump and related components, no n249 valve, DBW, etc.
Boost for 01 is around 10 psi and 97-00 is 8. 01 gets a k03s which is not the cause for more power, only durability. More agressive fuel map and timing was used for the +20 hp just like how a chip works. It has nothing to do with the turbo or vvt.
Depending on how much power you want.... Usually 250-300hp is a fun enough # for a DD.... If I were you and only if it's a manual tranny, I'd save up for a SC and clutch. If you want more power than that, if you cant stand your tacky wood trim, chrome window trim, genuine cracked leather seats, and if you can live without power seats, then by all means get a tqm.
