What bush has gone here - knock from front wheel
Old Feb 27, 2012 | 11:19 PM
sssstew's Avatar
Default What bush has gone here - knock from front wheel
Hi All
Ive got a knock from my front drivers wheel when going over speedbumps, or if i bounce the car up and down when parked by pushing down on the wing, but which bush is it thats likely to be gone ?
thanks all
Old Feb 27, 2012 | 11:27 PM
MetalMan's Avatar
From observation, it could be your tie rod end. I spy a ripped boot. If that's not it, my next guess would be lower control arms. Your best bet is to buy a control arm kit (such as from FCP Groten, ~$240 or less) and replace all control arms and both tie rod ends to eliminate all bushing/ball joint issues. This is definitely a DIY-type procedure if you have some mechanical knowledge and tools.
Old Feb 28, 2012 | 02:52 AM
jonbonesjones's Avatar
Moderator
I spy a torn tre boot. Also does that spring look cocked? It doesn't seem to line up correctly
Old Feb 28, 2012 | 08:03 AM
CCA4's Avatar
I third the TRE and you're right, I was thinking the same thing about the spring. Could be a shock mount?
Old Feb 28, 2012 | 10:02 AM
Moderator
Also another pic of behind the brake rotor at the bottom of the arm there are two more arms there that can be culprits.
Old Feb 28, 2012 | 10:36 AM
M5S5's Avatar
Tech Certified
I will third the tie rod. get rid of it even if there is no play. With the boot worn it will have a shortened life. Ditto on the springs also , something does not look right with the way they are sitting.
One more thing. I find it best to check the upper arms with the tires on & the weight of the vehicle on them. with the suspension hanging it takes up any play in the worn ball jount end. Reach inside the wheel well , give them a grab at the end & see if there is play.
Old Feb 28, 2012 | 11:05 AM
chocalotstarfish's Avatar
Super Moderator
WTF is up with that spring?!
Old Feb 28, 2012 | 10:12 PM
sssstew's Avatar
Thanks all for the replies.
Hmm the spring does look a bit funny, will have to drop it down and take another look.
Whats TRE? track/tie rod.....?
Heres a closer pic of the top bush with split
and the lower left in the pic which seems to look a bit tired :-
Old Mar 1, 2012 | 11:00 PM
Malinois's Avatar
Haha looks like you found your answer.
Old Mar 1, 2012 | 11:05 PM
sssstew's Avatar
ok so the track rod end needs doing as its split, but what about the lower bush in the last pic?
