What is this connected to the lower CA with electrical connection?
Old Nov 22, 2008 | 01:47 AM
Dallas09's Avatar
Default What is this connected to the lower CA with electrical connection?
My buddy has a 2001 A4 (1.8t, sport model i believe). He has this arm that goes right next to the front sway bar link on the driver side that is about the same length as the front sway bar but is perfectly straight and much thinner (1/4" thick?). Its connected to what looks like a little servo motor or something with an electrical connector running to it. The arm is connected to the lower CA with a clamp of some sort (the clamp looks very weak, and so does the arm so it doesnt seem like it carries much force). The wiring looks stock, although there were some performance things added before he got it (chip, and just discovered today: rear sway bar). The other weird thing is that there is only one of these on the driver side... I didnt have a camera otherwise i would have taken a picture... Any ideas??
Old Nov 22, 2008 | 09:16 AM
ImTheDevil's Avatar
No clue - I've been in my wheel wells several times and haven't noticed anything like that. Try and post a pic when you can and someone can likely identify it.
Old Nov 22, 2008 | 09:29 AM
manufan's Avatar
Sounds like headlight leveler motor.
Old Nov 22, 2008 | 09:41 AM
Jc61990's Avatar
hes got a prefacelift... dont the 00-01 have the xenons??
edit: didnt really read the whole post... reread and actually... that might be the sensor to get the temperature for the center disp on the cluster...
Old Nov 22, 2008 | 09:42 AM
ImTheDevil's Avatar
It's his friend's 01 that he's talking about. If it was the brake pad wear sensor, it'd be on the other side too.
Old Nov 22, 2008 | 09:58 AM
manufan's Avatar
The temp sensor is out in front of the a/c condensor. It's a headlight leveler.
Old Nov 22, 2008 | 10:21 AM
CCA4's Avatar
How come there's only one then?
Old Nov 22, 2008 | 10:32 AM
manufan's Avatar
It only needs one servo to send the data to both lights, they don't level independently.
Old Nov 22, 2008 | 10:37 AM
CCA4's Avatar
Ahhh i see. You face lift guys with your fancy headlights and your.... facelifts
Old Nov 22, 2008 | 02:31 PM
Dallas09's Avatar
Why would there be a sensor connected to the lower CA? Wouldnt it want something that senses the cars overall tilt more-so to see how the angle should be adjusted?
EDIT: But i guess thats what its for I found it in my service manual. Interesting.
Chatis
Nov 27, 2013 03:39 PM
NightRuiter
Dec 22, 2012 11:33 AM
jhanson25
Apr 30, 2010 11:49 PM
TeeterTawter
May 11, 2009 05:28 PM
Brandon318
Aug 13, 2006 04:13 AM
