What is the fuel pressure supposed to be on a 1.8T?
Old Feb 22, 2009 | 11:04 PM
K2's Avatar
K2
Question What is the fuel pressure supposed to be on a 1.8T?
I have an 01 1.8T and I am suspecting it has a fuel pump problem. I am getting a hesitation right after start up or if I get on it hard after driving for a bit, like getting on the highway fast. I dont think it is a plug as it is not constant, it may be an injector? I also dont think it is the turbo as it will do it at low rpms. I changed the fuel filter 2 months ago and it was fine for month, so I dont think it is that. What are the running and ignition on fuel pressure numbers supposed to be please? TIA
K2
Old Feb 23, 2009 | 01:43 PM
jiggleo's Avatar
vacuum hose connected running at idle 3.5 bar disconnected 4.0 bar and residual after 10 minutes at least 2.5 bar.
Old Feb 23, 2009 | 04:54 PM
whiskaz12200's Avatar
I had the same issue and it turned out to be the MAF sensor. Do you have a CEL displaying?
Old Feb 23, 2009 | 11:42 PM
K2's Avatar
K2
Thanks jiggleo.
Yes, I have not checked it since this problem though. I have needed an O2 sensor for a bit. I will take it in to get it checked. Thanks Whiskaz.
Chevrollac
Jul 22, 2014 01:17 PM
lolo22
Oct 12, 2012 05:14 PM
GoremanX
Oct 3, 2012 08:58 PM
vtraudt
May 9, 2011 11:08 AM
kerNol
Feb 25, 2009 09:53 PM
