What is limp mode
when your car senses something wrong it adjusts its settings to more conservative numbers to prevent damage. if you have a 1.8t it means that you are limited to 5psi of boost and lower timing and fuel maps. the car will still run, you can still get to where your going instead of being stuck on the side of the road, but you will notice a significant power loss.
P0411 is vag code 16795 which is "Secondary Air Injection System: Incorrect Flow Detected"
secondary air pump is a common problem but doesnt effect performance
P1141 is vag code 17549 " Load Calculation Cross Check: Implausible Value "
which is possibly a bad MAF or manifold pressure sensor or broken vacuum lines somewhere.
p1129 is a multiplicative long term fuel trim code.
p1127 is the same kind of code. also vag number 17535
you could have a leak somewhere or a bad MAF. you should clear the codes and check again in a week to see which ones come back.
im not sure if the generic autozone scanner does transmission codes too, you may need to go to a dealer or make a friend with vag-com.
