What Is The Proper Wheel Stud Length
Old Sep 18, 2011 | 07:24 PM
mtnxtreme's Avatar
Default What Is The Proper Wheel Stud Length
I bought some used aftermarket wheels and since they have center caps, I don't need chrome or stainless studs, but my stock studs only protrude out the wheel 5/8". Is this enough for strength? I don't have my stock wheels anymore so I can't measure how much they stick out. I i possible one of you guys has a stock wheel and stud and can measure for me, or tell me for sure if 5/8" is enough or what I should have to be safe.??
Old Sep 19, 2011 | 12:09 AM
ImTheDevil's Avatar
Stock bolts are 27mm length.
Old Sep 20, 2011 | 01:14 PM
mtnxtreme's Avatar
Thanks, but do you think I have enough going into the hub, if not how much longer than 27 should I order
Old Sep 20, 2011 | 08:55 PM
mschneidie's Avatar
The rule of thumb is the same amount of engagement as the diameter of the bolt. 5/8" is about 15mm, and the bolts are 14mm diameter, so you should be good to go.
rmr1499
Jun 4, 2014 01:45 PM
Mike-2ptzero
Jul 30, 2009 10:09 PM
Mike-2ptzero
B7 Models
Jul 12, 2009 10:52 AM
Mike-2ptzero
Jul 10, 2009 08:25 PM
jchaffee1
May 7, 2008 12:34 AM
