what r the symptoms of a loose camshaft chain?
Old Feb 6, 2008 | 11:15 PM
joel929's Avatar
Default what r the symptoms of a loose camshaft chain?
my engine compartment emits a loud pinging sound on startup. the sound is definetely coming from the top of the engine. the sound only lasts for about a half second. could a weak or improperly adjusted cam chain tensioner be to blame? also, the car will not start in very cold weather. not sure if that is related though.
thanks for any thoughts u might have
Old Feb 7, 2008 | 01:41 PM
cincyTT's Avatar
I'm make believe
Default RE: what r the symptoms of a loose camshaft chain?
the sound is often refered to as sounding like a desiel.
Old Feb 7, 2008 | 03:13 PM
McGovs2.7TB5's Avatar
ORIGINAL: cincyTT
Yep I had to replace my cam crank tensioner. It started with the symptoms you describe on start up but,after a few weeks it did sound like a diesel at idle. Was not cheap to replace,Ifound the part anywhere from $600-800 and if you can DIY you'll save a ton on labor.
Old Feb 8, 2008 | 09:28 AM
kraylon's Avatar
any write ups on that diy ^^^^^
Old Jul 12, 2008 | 05:40 PM
Sethg10's Avatar
If it's only happening at startup then thats normal. The tensioner is pressurized by oil, so after sitting the chain developes some slack. There is a tech bulletin addressing this issue. I think if it lasts longer than 4 seconds it would need replacement, but you should look it up to be sure. If it only lasts a second or two then it's normal.
jaumju
Nov 8, 2013 09:28 AM
tingj
B7 Models
Aug 27, 2009 11:27 AM
Got2Speed
Apr 29, 2008 09:14 PM
joel929
Feb 6, 2008 11:15 PM
dberg
Nov 25, 2006 04:08 PM
