What reads/measures the boost pressure
Old Dec 14, 2008 | 08:27 AM
dylsaudi's Avatar
Post What reads/measures the boost pressure
On a 96 A4 1.8t, what reads/measures the boost pressure ? I understand that the n75 valve regulates the pressure to the wastegate via the ecu/electrontic plug, but what sends the boost pressure reading to the ECU? I don't believe that there is a manifold absolute pressure sensor on this year of car. where does the ecu get its actual vs requested boost reading from ?
Old Dec 14, 2008 | 09:56 AM
CRAZYHAWK's Avatar
It might be the diverter valve. The ECU also uses the MAF sensor
to determine the amount of air in the intake.
Old Dec 14, 2008 | 10:44 AM
FASTER's Avatar
Tech Slut
i believe it would also be the n75.
Old Dec 14, 2008 | 11:27 AM
cincyTT's Avatar
I'm make believe
The map sends the actual to the ecu. Since the AEB doesnt have one, its all dependent on the g/s value of the maf
Old Dec 14, 2008 | 12:48 PM
FASTER's Avatar
Tech Slut
^^ there you go
Old Dec 14, 2008 | 02:41 PM
dylsaudi's Avatar
Sorry, what is the 'g/s' value ?
Old Dec 14, 2008 | 04:14 PM
dylsaudi's Avatar
does th n75 'read' boost pressure ?
Old Dec 14, 2008 | 04:18 PM
cincyTT's Avatar
I'm make believe
grams/sec (wrote the wrong thing in PM)
n75 bleeds off boost pressure, not read it. Its just a dump boost controller
Old Dec 14, 2008 | 04:35 PM
dylsaudi's Avatar
Thats what I thought as regards the N75. So there is nothing that reads actual boost pressure on a AEB engine ?
Old Dec 14, 2008 | 04:41 PM
cincyTT's Avatar
I'm make believe
no, thats why you need to run a maf and a boost gauge. Not sure why this is such a big deal for you, the maf and o2 sensor do a good job at regulating a/f. Its not as good as the newer ecu's that have a wideband o2 and map, but there are still A4's running around with 1000cc tunes from Tapp/eurodyne on a gt35r and making great power.
