what are some possible engine swaps for a 96 audi a4 2.8 quattro?
Old Apr 7, 2012 | 05:37 PM
airguard350's Avatar
Tech Guru
Originally Posted by Bigdog7373
Work with what you got. Get some head work done. Bore it out. Get a turbo or supercharger. You can make nice power with a blown or turbo v6.
Not a 12v, you can't!
Old Apr 7, 2012 | 06:33 PM
Lornnn's Avatar
MotoDyne - Performance Technologies LLC -- Audi 12valve V6 Supercharger
Old Apr 7, 2012 | 08:13 PM
jonbonesjones's Avatar
Moderator
apparently its a piece of ****
Old Apr 8, 2012 | 12:12 AM
ImTheDevil's Avatar
^^^ this. Always saw bad feedback about kits missing parts and an incomplete tune. Therefore Pat is right - not on a 12v (unless you spray it or fab all your own stuff).
Old Apr 8, 2012 | 08:49 AM
Bigdog7373's Avatar
You guys make it seem like because it has 12 valves it will never make decent power. Many of the highest performing engines in the world have 2 valves per cylinder. The probelem it has now is that the valves are too small for it to breathe well. Port and polish, larger valves, bigger cams. That's it for head work. Bore the block .030 over with new pistons. Get the compression ratio down a little, maybe 9:1. Then find a vortech supercharger and make, or have made, a custom bracket for it. Get pullies for 9psi of boost. Bore out the throttle body and port match the intake mani to the heads. Buy or build long tube headers into 2.5inch true dual exhaust with a crossover pipe, or single 3 inch exhaust. Use high flow cats and free flowing mufflers.
This will cost is the $4000 range and will make 400hp easy. That's if you do the work yourself. Expect $7-8000 to have it done for you.
Old Apr 8, 2012 | 03:06 PM
moarboost's Avatar
Originally Posted by jonbonesjones
10k?
i call bullshit
If you're doing it, you should do it right as your safety depends on it.
That's not to mention getting it to work reliably. So you can either factor in the cost of doing it twice, or proper parts, labor (including machining) and all the other small details aesthetic upgrades.
Good rule of thumb, bud, unless it's a smallblock chev, take your realistic estimated figure and double it.
I'm sure if you swap in a stock motor without even resealing it you can do it for around 5 points, but whats the point? If you're doing a swap, you might as well do **** to it while its out.
Old Apr 9, 2012 | 07:14 AM
Moderator
i agree 10k, if you do the swap right and upgrade what you will eventually upgrade. but an s4 engine can be had for under a grand. it was a factory engine in our chassis so the rest is plug an play if you have everything for the s4 front. it all just turns around to buy an s4. BUT i somehow found a good 4.2 engine for $250 so i think i will keep my a4 and make this 4.2 fit.
Old Apr 9, 2012 | 09:54 PM
  #18
Tech Guru
Which is fine and dandy. Also, most of us already know that. Most of us also now that you'd have to have a screw loose to burn $7-10k on a '96-'97 12v. Don't forget that you'll also need new rods. Larger valves MIGHT be able to be scavenged from an S4, but it's a 30v and new cams will have to be full custom. Also, you'll have to run a standalone tune for the S/C as well as grab up new, larger injectors for your bored out throttle body.
Old Apr 10, 2012 | 06:43 AM
  #19
Moderator
^^aka more trouble than buying an s4. the only real motor swaps that are practical are a 4.2 v8 or any for of the inline 5. Both bolt up to the tranny and somehow fit in the small engine bay of the a4. Your gonna spend some money but you gonna have a custom car that you built vs a cookie cutter s4. Look around for a while you can find engines cheap. I got a good v8 for 250. the only thing i have to buy to make it happen now is a form of stand alone. Your gonna of course spend more if you have a shop do it or you go a turbo route.
Old Apr 10, 2012 | 08:48 AM
  #20
shipo's Avatar
Even if you get the V8 installed and everything working perfectly, pound-for-pound, poop will be worth more than your modified Audi. Like it or don't, believe it or not, you're way better off selling the A4 and buying a "cookie cutter" with the engine you really want installed in the factory.
