What is that sound???
Old Nov 27, 2012 | 04:18 PM
A6fl's Avatar
Default What is that sound???
Ok, so replaced auto transmission. Scanned with vag-com and only a MAF error on the engine controller. My issue is when I start it I hear a sound best described as when kids put a playing card by the spokes of their tires. Maybe a little more metallic but similar. It varies with RPM and load. I made sure the transmission is filled properly and it seems to be happy.
In my mind it sounds like something is rubbing on that pesky metal gasket that goes between the bellhousing and the motor. I pray this inst what a bad trans pump sound like. Help please
Old Nov 27, 2012 | 04:55 PM
jonbonesjones's Avatar
Moderator
heatshield loose hitting the driveshaft.
Old Nov 27, 2012 | 04:57 PM
A6fl's Avatar
Good idea, but in park/neutral? I made sure the torque converter was seated, and when I mated the trans up I could still rotate the TC with a screwdriver so I am pretty sure its not a cracked flywheel. This is driving me bonkers. Bad trans pumps dont click like that do they?
Old Nov 27, 2012 | 05:08 PM
Moderator
pump shouldn't be clocking. and the engine is still vibrating at idle. Does the sound change with rpms in park and neutral as well? Any slippage or missing shifts?
Old Nov 27, 2012 | 05:25 PM
A6fl's Avatar
Seems to speed up with rpm changes. Slight difference in gear vs park/neutral but may be load related not sure. Shifting is great.
Old Nov 27, 2012 | 05:33 PM
curtisw511's Avatar
new to this site, should I buy a 2000 audi s4 with 200,000 miles on it for $4000?
Old Nov 27, 2012 | 05:51 PM
Moderator
completely wrong thread and forum but yes.
Old Nov 27, 2012 | 05:55 PM
curtisw511's Avatar
haha thank you, yeah i just realized that but im meeting the guy tonight and needed a quick answer, sorry for jumping in your thread
Old Nov 27, 2012 | 06:12 PM
Moderator
no problem jump on the deal and enjoy that speed machine.
Old Nov 27, 2012 | 07:25 PM
Mad Cow's Avatar
Sounds like you might have a small exhaust leak at the turbo or header, try seafoaming it and see if smoke comes out anywhere but the tailpipe.
