What spark plugs should I run in my current setup ???
Old Jan 26, 2012 | 02:14 PM
Acuna989's Avatar
Default What spark plugs should I run in my current setup ???
Im running a modified APR stage three kit with a Gt28r. What spark plugs should I be using and at what gap?
Old Jan 26, 2012 | 02:22 PM
MetalMan's Avatar
Pretty sure NGK BKR7E plugs gapped .025-.028" would be ideal. I wonder what others think, though.
Old Jan 29, 2012 | 12:14 AM
Acuna989's Avatar
Couldn't find any BKR7E's in town, so I had to go with BKR6E's gaped at .28. Seems to be running a little rough. Im going to try and order some BKR7E's online. Anybody know of a cheap source ?
Old Jan 29, 2012 | 10:39 AM
ImTheDevil's Avatar
I run BKR7E plugs in my 30v. Got them at Advance Auto for $2.79 each.
Old Jan 29, 2012 | 10:49 AM
turbo kraut's Avatar
Tech Guru
Bosch 7403 fr5dtc's. Are what I'm going to try eith my gtrs 630 uni setup. I've been running champion coppers, time to switch it up a bit
Old Jan 29, 2012 | 09:57 PM
Andrew149's Avatar
run those bosch and they will go bad in 3,000 miles stick to ngk's
Old Jan 30, 2012 | 01:27 AM
HulkB5's Avatar
Bk7re
I run them on a gt3076r gapped at .032 and they don't get blown out
Old Jan 30, 2012 | 08:42 PM
airguard350's Avatar
Tech Guru
Run Pulstars!
Old Jan 30, 2012 | 09:20 PM
Tech Guru
What works in you gti isn't necessarily the same or will/won't work in my car w/ my setup or his. Keep to what you know not what you think. Stick to the facts not hearsay.
If I buy those and go over 3k miles will you re-imbuese me or let me take a **** on your car?
Cause if those plugs were so shitty they wouldn't run them in porshe cars
Old Jan 30, 2012 | 11:52 PM
Andrew149's Avatar
did you forget i had a b5? google those plugs and you will find out there the best plugs and all assuden they dont work as well in 3,000 miles don't try to act like i don't know what im talking about because i own a gti i did own a b5 also and i also work on 1.8ts all the time from friends and familes AND yes its a fact i know my b5's
