Whats insp
Old Oct 29, 2010 | 09:46 PM
lolo22's Avatar
Default Whats insp
I have a 98 pre facelift and today the letters insp appeared on my gauges were it would say mileage. What does that mean.
Old Oct 30, 2010 | 03:11 AM
colony777's Avatar
inspiration...... ha no. its a thing that happens once a year, almost like christmas, except not at all. inspection.
Old Oct 30, 2010 | 06:51 AM
lolo22's Avatar
Will that go away its self or does something need to be reset.
Old Oct 30, 2010 | 02:06 PM
colony777's Avatar
look up a service light reset. you have to do something using the stalks in your cluster and the ignition
Old Oct 30, 2010 | 02:21 PM
chocalotstarfish's Avatar
Super Moderator
When the dealer services your car, they are supposed to reset the oil or service interval warning light that comes on in place of your trip odometer when you start your car. It can be temporarily reset, by pushing the odometer reset. But when the ignition is turned off, the service warning will reappear when you restart your car. To reset it permanently, follow these instructions:
1. Insert your key into the ignition.
2. Push in the odometer reset button, hold it in, and turn the key to the first click.
3. The display should read either "oil" or "service" if it does not, repeat steps #1 and #2.
4. To reset, pull out your instrument light dimmer button at the bottom of the tachometer.
5. Turn the ignition to the off position. When the ignition is turned back on, the display should be back to the trip odometer.
Note: This procedure has been confirmed on '98 and '99 model year A4's.
here.
Old Nov 1, 2010 | 12:00 AM
lolo22's Avatar
Thanks I will try this tomorrow. I was getting scared I just bought coilovers and headlights and thought crap something might be wrong with the engine.
Old Nov 1, 2010 | 12:42 AM
Skythe's Avatar
But what does it mean? Every time I change the oil, I'll need to reset this?
I'm aware it signals inspection. But "oil" ?
Old Nov 1, 2010 | 04:26 AM
MetalMan's Avatar
It means INSPection. It's a part of a service reminder that comes up every 30000km or so, depending on the mileage it was programmed at.
Rusci53audi
Dec 8, 2010 09:21 PM
duburban
Jan 4, 2007 12:06 AM
bleedgreen11
Oct 24, 2005 07:36 PM
Transverse
Nov 5, 2004 08:21 PM
rpacobra
Jul 15, 2003 04:01 PM
