Wheel size change
Old Dec 19, 2011 | 11:02 PM
A4driver17's Avatar
Default Wheel size change
Hey everybody, Its me again. So I thought about it today and I am wondering what the pros/cons of switching out my wheels would be. I am currently using the stock 97 a4 rims with all season performance tires. I'm wanting to swap out for my 15" low profile rims with low profile tires (which are terrible in snow rain and all that other good stuff) but I think if i don't do anything stupid and keep it slow I won't have a problem. So in your opinions what should I do?? Thanks guys!
Old Dec 19, 2011 | 11:58 PM
kriptonik's Avatar
I'm confused. So you want to replace the tires with low profile tires? What kind of tires are they?
Lower profile tires would mess with the accuracy of your speedometer. That's the only downside I can think of.
Old Dec 20, 2011 | 07:10 AM
Lazydog's Avatar
Last Place - just "necause"
Wheels, you called them that corectly the first time. Rims are something that is the outer edge of a container, glass or wheel.
Well you would be thinking wrong. Sounds like your LP's are slicks and would be good on the trace and no where else. You need to replace them if they are that bad.
1. Buy new tires before you swap the wheels out.
2. Swap the wheels after you get new tires.
Old Dec 20, 2011 | 07:35 AM
A4driver17's Avatar
Ok so let me rephrase what I was trying to say. A bit of confusion has come up lol. I want to sea my 97 a4 stock rims that have all season performance tires and ar 16" with 15" enkei rims that have low profile tires and don't come with any of tire size. So besides the fact it would look weird with smaller rims. What should I do?
Old Dec 20, 2011 | 08:55 AM
CCA4's Avatar
As Kriptonik mentioned, changing the size of the wheel without changing the aspect ratio of the tire will throw off your speedometer, and also probably look silly. For the stock 16" sport wheels you should be running 205/55-16 or thereabouts. For 15" wheels you'll want something like 205/60-15, depending on the width of the wheel. I have OEM Celebrations that are 17x7.5" and I run 225/45-17 Goodyears. Changing the width/aspect ratio of the tire according to wheel size will keep the overall rolling diameter roughly the same which will help keep your speedometer accurate.
Old Dec 21, 2011 | 08:47 AM
A4driver17's Avatar
Awesome. Thanks!
Old Dec 22, 2011 | 07:30 AM
Lazydog's Avatar
You could look at the site listed below to finding a tire setup that would come close to what you have now.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Brian2417
Feb 9, 2010 01:04 AM
mystrodo
Sep 2, 2009 09:41 AM
vance
Apr 1, 2008 01:09 AM
sinreyn
Oct 26, 2007 10:56 PM
amwysk
Feb 7, 2007 03:50 PM
