where to find tranny mounts and is it easy to install??
Old Oct 16, 2009 | 04:43 PM
1.8TNYC's Avatar
Default where to find tranny mounts and is it easy to install??
well i have some play on 1st and 2nd and when i down shift.
i want to change the tranny mount asap before something worst happens.
{1.8t 5spd}
Old Oct 16, 2009 | 04:50 PM
blackwat5r's Avatar
You need 2, one left one right. I run a Stern for the left and an 034 for the right. Some say the Stern is too stiff and adds too much vibration. I like mine and the vibes arent bad...more noticeable with the a/c on. You should upgrade the motor mounts as well; esp the snub or else it will vibe like a mf er goin into 1st.
Install is straightforward, took bout 30 mins for me to do both and Stern inlcudes instructions if you need them.
Old Oct 16, 2009 | 05:16 PM
Mike-2ptzero's Avatar
Here you go.
Right now Stern is doing their road testing of their new transmission mount which will work on the passenger side of the 1.8t and both sides for the 2.8/2.7t.
Old Oct 16, 2009 | 05:40 PM
1.8TNYC's Avatar
http://www.purems.com/products/products.php/CA=1484
alot of people from the other sites are telling me just stick to oem mounts
Old Oct 16, 2009 | 08:55 PM
blackwat5r's Avatar
Well if you are going to make more substanially more power in the future (bt) then you should upgrade to either the Stern or 034 mounts. If not then new stock mounts will be just fine.
Old Oct 17, 2009 | 05:07 PM
1.8TNYC's Avatar
nodoubt, thanks on the info.
is there a diy of the install somewhere?
Old Oct 17, 2009 | 05:32 PM
blackwat5r's Avatar
Not sure if there's a diy but all you need to do it put up the car on jackstands, support the tranny with a jack and replace one mount at a time-done. Some say to let the car idle for a minute before you torque the bolts down.
A6Isaac
Jul 23, 2013 09:08 PM
mmhyson
Nov 28, 2008 10:05 PM
A4Sooner
Feb 24, 2008 07:23 PM
TKneedsS4
Jan 25, 2008 07:30 AM
Kyle09
Dec 5, 2007 10:47 PM
