whinning sound under hard acceleration
I thought I was getting belt squeeling under hard acceleration, so I replaced the belts. the sound is still there. the manual tensioner on the AC compressor did seem to have a little side play in it. could that be the culprit?
Sorry, I thought I had all the info typed into my garage, but I don't. Its a 97' quattro 1.8T. under normal driving you never hear it, just when you put your foot in it. thats why I thought the belts were slipping. (sounded just like it). there's no CEL on. I bought the car with 86K miles and has now turned 91K. I was going to change the timing belt while I had the front end pulled off, but it looks like the previous owner beat me to it. (belt looked like new & timing cover had a crack in it.) The noise doesn't appear to affect the performance, just kinda irritating is all.
If you don't know 100% fact that the T-belt was changed, you should really change it. How do you know someone didn't just crack the cover to look at the T-belt and never actually changed it?
As for the squeal, remove the belts and take a quick drive without the accessory belts (just enough to determine the sound... no longer). If the noise is gone, you've found the culprit.
