white smoke?
i lose coolant only when i drive on the highway. if it's my headgaskets i'm forked cuz i'm freaking broke. i put in a bottle of stop leak seal conditioner thingymajiggy and i jsut hope it does the trick.
its not at start up. only when its been sitting for over a minute. the car is driving fine. the only other thing i noticed was at low rpm's it kinda gives of this really throaty sound from the front of the car that was not there before. but it might just be an exhaust leak. it will usually smoke for a bit and then stop for a while. some one just tell me the procedures i need to take to figure it out. i will have to check my codes i already have a cel from tp so not sure.
If you know someone with a sniffer they can check your hydro-carbon level from your coolant fill tank. If not the next best thing would be a combustion leak tester. Pretty simple, you fill a tube up with the liquid and place it over the coolant fill hole and give the bulb a few pumps. If the liquid or dye changes color then your head is probably leaking. Here is a link for one on ebay. But from what your saying it's during start up then it's most likely just condensation in the exhuast pipes.
http://cgi.ebay.com/UNIVERSAL-CYLIND...sid=p1638.m122
