White smoke coming from exhaust.... bad head gasket?
So just a few days ago, I drove my car and noticed that it smelled really bad inside the cabin. I looked at the rear view mirror and saw a cloud of white smoke behind me at a stop light. I felt bad for the guy behind me because if I could smell it with the windows up, it must smell real bad to the person behind me. The smoke and smell is present when idling or driving.
In any case, I'm led to believe that it's the head gasket b/c of a slightly lower coolant level, but is the head gasket a normal item that goes out over time? I didn't have any engine overheating problems and the oil was changed every 3K with synthetic and I just did a coolant flush a few months ago since my thermostat went bad too. Is there something else I should check out before I start replacing the head gasket?
TIA!
TIA!
Do a compression check and if it is the head gasket you'll know. I just went through the exact same thing only to find out that the oil seal in the turbo had failed which caused it to put out white smoke from my tailpipe as well which smelled really bad. It is in the process of being replaced but I would have a mechanic do a full check on the vehicle just to make sure so you don't start spending a lot of money in the wrong place.
Do a leakdown and compression test before even touching a wrench.
[QUOTE=kraylon;1110111]Well a compression test will let you know if there is a problem in that area, a leak down will tell you exactly where the leak is at.
